Stalled Z-CASE P50 v1.1: Innovative console-style SFF PC case
Status
Not open for further replies.
britsches
Did somebody else already notice, that the powerbutton is completely different as on the pictures?
DuKe
Link to parts please. That does look badass side venting the aio!
I bought everything on the official alphacool website. and I do not understand when you say that it is poorly ventilated it is perfect for me it does not exceed 60
parts links:
cpu+pump https://www.alphacool.com/shop/cpu-cooler/intel-amd/23937/alphacool-eisbaer-lt-solo-black
tube kit https://www.alphacool.com/shop/new-...ion-set-900-tubes-and-fittings?number=1012767
fitting https://www.alphacool.com/shop/fitt...fitting-g1/4-knurled-matte-black?number=62434
copper raidator https://www.alphacool.com/shop/radi...er-x-flow-40mm-triple-radiator?number=1015717
Reactions: Jabaniz
DuKe
If you are right, but I do not worry because if you want it with led on aliexpress you have it for about 2€ and so you choose the color that you like
P.D the leds working 5v
Arch
While the main chassis looks good, they came short to deliver the small details of perfection as stated on their website. I hope they can resolve and adjust/fix their QC. As a consumer, we should expect what was promised. But I guess this is the fallacy of being 1st in production.
DuKe
I've been investigating how to get to see with the dark glass because the truth is barely visible XD. A strip of smd LEDs would come in luxury, which I have already ordered, I have tested with a flashlight and the truth is that I love it more like that
AstroWan
33
Wow, with the fact that the radiator fits perfectly with the tempered glass, I may do the same setup as you and attempt to put some LED strips in. I really love how it turned out on your end!
Also though, on top of that the PSU shrould at the very bottom, did you cut the piece to let you place the fitting on the bottom of the radiator and to give space to mount the radiator?
DuKe
if I had to cut the bottom of the psu support so that the radiator could fit, and also remove the ssd support to make it as narrow as possible.
On the led strip I recommend that you get a very narrow one and that they are smd leds
chrimen
52
What cpu are you running in there?
Status
