CPU Yet another Lian Lie H2O Build.
nmlvaio101
Hey guys,
I am very new at building and I want to stick with a Lian Li Dan H2O:
1) Case - Lian Li A4 H2O
2) Motherboard - Asus Z690-I
3) CPU - i7 - 12700K- series 12
4) Ram - Corsair vengeance - 32gb (2x16) DDR5 5600- overkill?
5) PSU - Corsair Platinum SF750 w/ SFF sleeve cable
6) GPU - Asus ROG Strix 3070 TI
7) Storage main - Samsung 990 2TB
8. Storage secondary - WD Black - 4TB
9) CPU Cooler - EK 240mm AIO Basic - should I replace the stock fans for something else?
Concerns? The motherboard notes it can take both LGA 1200 and the new LGA 1400. Is there an issue with the using EK’s Basic AIO with LGA 1200 or should I wait and buy the bracket kit?
2,668
2,792
z690 is socket 1700 but the Asus also has 1200 socket mounting holes so you should be fine with the EK.
