Production XTIA Xproto-L , Sandwich layout,No limitation on GPU size
XTIA Design Studio
70
103
With the release of 30 series graphics cards, Xproto encountered some challenges.
1:Not compatible with some ultra-long graphics cards
2:Not compatible with three-slot panel graphics cards including 3090FE
3:SFX power supply options are limited and cannot support ultra-high power consumption requirements (Some clients want ATX PSU)
But solving all the above problems will lose the compactness of XPROTO itself, so we have made some adjustments to the size of the case on the basis of maintaining the same butterfly structure, so we have XPROTO-L.
Xptoto-L has the following changes compared to Xproto
1: 3 Slots IO panel GPUs supported *( RTX 3090FE for example)
2: 3 cm longer SFX/ SFX-L/ ATX PSU*(14 cm-18cm) supported *( smaller than 15*15*8.6cM ATX PSU Recommended,
larger than this size like Corsair RM-X series ,have to rotate the PSU to install)
3: The modules(Like AIO blancket) of Xproto and Xproto-L are common
4:Special ventilation design For RTX30 series
5: Nearly no GPU size limitation ( UP to 345 mm length GPU support)
See more at XTIA.COM.CN
XTIA Design Studio
70
103
Two Xproto-L exampes from our clients
1: 6800XT+360AIO+15*15*8.6cm ATX PSU
@HEFAN
2: 3090FE+C8I DTX MB(Not recommend) + 360AIO+ 120Fan*3 + 15*17ATX PSU
@战熊
yoyo55
45
27
So I've decided on moving my current system and a future build into the Xproto L case. The GPU clearance states 345mm. The new Asus RTX 4090 TUF comes in at 348. Anyone have any idea if there's a few mm clearance or is the 345 absolute max?
