From Reddit:
Hi, made an account to hopefully anyone else probably in the same situation. I decided to take a gamble on this because I wasn't sure either.
I have the XFX Radeon RX 6700 XT QICK 319 black and it is possible, but the shroud makes it quite difficult. Out of the box i was able to fit the card in, but it was VERY snug(as in rubbing the inside wall). You'll have no wiggle room and need to take your time without modifications.
I eventually shaved off 2mm from the shroud edge and it fit perfectly smooth, but I'd still recommend moving the PSU power cord out of the routing and tuck it a bit behind the GPU for best fit.
