For reference; I am still running these three APU builds;
Now I am on the hunt for a new case for my next APU Build with (AMD Ryzen7 8700G) and maybe the (Asus B650E-I) mini-ITX motherboard. In the image below (on the right) are two large capacity external USB storage drives. I want those to exist inside the case in the form of (1 or 2) large capacity 2.5" SATA drives. That brings me to my case selection problem.
My old silver-colored K39 Case (47mm CPU cooler height) has the motherboard mounted mid-case and therefore sacrifices CPU height (only 47mm clearance). It requires too much cramming/shaving/cutting to install a decent CPU fan/cooler.
My new black colored A09 Mini ITX Desktop case has the motherboard mounted all the way to one side. That solves the CPU height problem. But no room is available to mount any Internal 2.5" Sata drives.
Yes, I know about those external SATA cases that allows you to slide your SATA drive into an external case and then connect the external case via a USB cable. Pfft; That is pretty much what I have now.
I think my ideal case does not exist? Any Suggestions?
- InWin Chopin B450 mini-ITX Ryzen5 3400G
- Brickless B550 mini-ITX Ryzen5-4650G
- A09 Mini ITX Desktop Core i5-12600K
