CPU: Ryzen 7 2700X
GPU: Gigabyte RTX 2070 Mini
Mobo: Asus Strix X470-I
RAM: 16Gb G.Skill Trident Z
SSD: M.2 NVME x2
CPU Cooler: Corsair H60
Case: Dan A4 SFX v3
I have used OuterVision power supply calculator to get load wattages ranging from 366W to over 450W with various tweaks to this configuration (clock speeds, voltage etc.). The PSUs I had in mind for this build are Corsair SF450 and SF600, both platinum efficiency. I know that 450W will do because gaming won't be stressing both CPU and GPU to the max at the same time anyway but I still have that feeling that maybe I should go with the 600W one just to be safe. But then again I have read that PSUs are most efficient at over 50% loads which that 600W one would probably only see once in a blue moon. Would the SF450 also run hotter than SF600 with the load these parts generate?
SSD: M.2 NVME x2
Case: Dan A4 SFX v3
