Power Supply Which braided cables will fit Corsair SF600?
Quicksandman
I am building my first mini ITX case and just purchased a Corsair SF600 PSU. I was hoping to get some braided cables to help with cable flexibility and overall management. Does anybody have a recommendation for which cables to go with? and also, are there any shorter ones available since I will not be needing full length?
Tazpr
553
429
I have 150mm 24 pin, 150mm EPS and 350mm PCI-e. But you can go shorter on the 24 pin.
I reckon 100mm 24 pin, 150mm EPS and 350mm PCI-e is good.
What case is that btw?
Reactions: Quicksandman
Quicksandman
Ok, so are you recommending cutting my own cables? Or do you know where I can get 100mm 24pin, 150mm eps and 350mm pci-e braided cables?
It’s the new Geeek A60 case
NeoConker
For this case the EPS cable needs to be a little longer, because the I/O shield towards in the back, the cable need to cross all the motherboard to get to PSU. 250mm.
The PCI-E could be shorter, the GPU end, where the power connectors are and the PSU are very close, just on oposite chamber. 200mm
And the length of the 24 pin varies on the which motherboard you gonna use. Asrock often put the 24 pin in the middle of the board, the Asus Strix on the edge.
