Hi, everyone!
First off, I want to thank this community for the inspiration and lots of golden threads with food for thought. Lurking since my first proper SFF build in January (images in my profile), but this summer decided to push further with a custom case.
Current project status summary: [will be updated when needed]
Prototype assembled with real hardware (Z390 ITX, 8700K, 1070ti, 2xNVMe).
Short facts: [will be updated when needed]
I've seen a couple of crammed builds like petricor's brickless S4M and decided to do something watercooled too especially since I have some hardware and experience from my January build. I also liked the functional beauty of CNC'd internals of the FormD T1 case. So I started learning parametric modeling in Fusion 360 to create something similar, but very custom and designed around my GPU and motherboard.
Prototype:
Current design render:
See spoiler below for the original post with more text!
- Bounding box: 253mm x 230mm x 95mm (excluding protrusions, namely the bottom feet)
- Volume: 5.5L (subject to change)
- Thick 184mm radiator support
- Only water-cooled
Prototype:
The hardware:
I'm a big fan of Alphacool since they have a lot of SFF-freindly offerings so I have started researching radiators to slap on something dimensionally similar to Velka 3, but Alphacool 2x92mm rads was a bit too long. Eventually I stumbled upon Black Ice Nemesis M184 GTX by Hardware Labs which supports 2 92mm fans, is 213mm long and 54mm thick which fits perfectly in the front of the case. The downside was protruding fittings instead of flush holes, but eventually it led me to the concept of a load-bearing radiator. The idea was to design brackets enveloping those fittings and incorporating them into the case design.
For the pump I could go with Eisbaer LT, but what's the fun in that if I can have a proper reservoir (Eisstation 40 DC-LT). This led to a slight problem of not enough vertical space due to Flex PSU + riser + GPU giving no chance to fit even just the DC-LT with plexiglass top.
Warning: this photo is just an early work in progress, next pictures show the up-to-date renders of a newer CAD design!
So, back to drawing board, where I finally came up with an "inverted Flex ATX sandwich" layout. The motherboard PCI slot is now at the bottom, motherboard on the right side of the case and GPU backplate is facing the left side panel. Now the riser and GPU PCI slot can slide lower next to the Flex PSU leaving about 5.5cm of space above the GPU for the Eisstation with DC-LT pump. My plan is to use 13mm soft tubing and regular fittings (not ultrathin tubes with pneumatic fittings).
I usually find the specs a bit boring, but here is the hardware I'm currently using and planning to use for this build too:
I have 3D-printed most of the parts, trying to keep as much "flat" pieces as possible (motherboard tray and back panel are completely flat, the side panels will be flat too).
After assembling the prototype I plan to order all the flat pieces in lazer-cut aluminum. The pieces with complex shapes will stay 3D-printed, but I really want them to be CNC'd (it's hell of expensive though).
Probably I can show some photos of the 3D parts assembled and looking kind of as a PC case next week...
Final thoughts:
I'm pretty sure the cable management will be tough, might go with customizing the cables which is Terra incognita for me for now.
I want to complete the build as soon as possible, but component availability may play its role and postpone it 'til September!
Bonus:
A photo of my GPU: 173mm in length, with a stubby but shiny custom output port cover.
- Zotac 1070ti with Alphacool waterblock
- ASRock Phantom/Gaming ITX AC
- i7-8700K
- dual NVMe SSD
- 2x NF-A9x14 HS-PWM chromax
- Black Ice Nemesis M184 GTX radiator
Final thoughts:
Bonus:
