Using a DC-LT Pump without pump top
GrievousJack
Is there any way I can modify this Aphacool DC-LT 2600 to integrate into a reservoir-less, soft tubing G 1/4" loop? I need to be able to fit a very small, standalone pump within the system, and without using any pump tops. Is there anything I can do, whether purchasing a 3d print, or other, in order to fit the pump into my loop? Space is extremely limited in this system. (See attached cave-drawing for an idea of what I'm talking about.
Image: https://ibb.co/vQphDVR
Curiosity
Apr 30, 2016
724
838
I'm in a similar position. Currently I'm slowly working on a low profile pump top since I wanted to use a supremacy Evo for my CPU.
Is the alphacool dclt pump top too thick for your use?
kotproger
136
131
vk.com
For my experiments, I also encountered the problem of finding small water pumps. Had to be guided by the principle - there is no suitable - do it yourself)
