Hey Guys,
I am thinking of preparing some content looking at the best LP cooler under 50mm. My rationale for this is that I haven't been able to find anything like this on the interwebs and it seems to be a common bone of contention on these boards. I have the following coolers already:
- Intel Stock Cooler w/ copper core
- Noctua L9i
- Thermolab LP53 (would test with NF-A9x14)
- Cryorig C7
- Zalman CNPS2X
- Scythe Kozuti
Can anyone suggest any other coolers I would need to add to this to make the list more complete? The Silverstone AR-05 and ID Cooling VC-45 are the first two that come to mind, but I'm not super sure I want to bury another 100 bucks into coolers that I definitely will never use (VC-45 sounds particularly poor). Really I want to cover the popular choices and compare them back against the stock cooler. Also anyone with background on measuring sound, I wouldn't mind being able to monitor both dBA as well as frequency or timbre of the fan as I think this aspect is often as important if not more so than the absolute volume of the fan.
Other content I would like to have a go at include:
- Underclocking and performance --> Pick a few key benchmarks like Unigine Heaven/Valley, Firestrike and Timespy and run them with the CPU at a variety of progressively larger underclocks and with a selection of GPUs (GTX 1050ti, 1060, 1080). The rationale with this would be to see how much under clocking actually affects real world performance (FPS on Heaven/Valley) vs. synthetic benchmarks as well as thermals and power consumption.
- Fan ducting and heatsink shrouding --> Would likely try to run this using the Noctua L9i in an S4 mini. Would look at a narrow duct straight up to the case side panel, a broad shroud doing the same thing as well as a shroud over the fins and some form of sealing between the fan and the heatsink to see if efforts to increase both the amount of air passing over the fins as well as forcing air to travel the entire distance of the fin had any significant effects on performance.
- Noctua L9i
- Cryorig C7
- Zalman CNPS2X
- Scythe Kozuti
