I have already ordered an S4 Mini from Josh's secret shop (thanks a ton!) and I originally planned to put an i5-7500 (currently $192) with a Gigabyte GA H270N Motherboard (currently $116). I was looking online at some cpus and my local Microcenter listed an i5 7600K for only $199, what a deal! So many questions popped up in my head:
-Is the increase in TDP worth the extra clockspeed?
-The Gigabyte H270 Board has type 2 usb 3.1, but the ($3 cheaper) AsRock Z270 board doesnt, is type 2 usb 3.1 even worth it?
-If I do decide on the 7600k, would I get this with the H270, or should I get the Z270 instead?
-Since the 7600k draws 91W, would i need to change from an HDPlex 160w to a 300w?
-Would a 7600k even be practical in an S4 Mini given the compact nature of the case and the higher clockspeed of the cpu?
I'm not sure which one I should opt for, and i dont wanna go too far over my budget of around $1200, so I'm going to ask my fellow SFF Forum members. What would you go for in this situation? Yes I know, my choice should depend on what I'm looking for in a system and what noise levels are acceptable and all that jazz. I'd like your opinion, based on whatever you look for in a pc. Your opinions would really, really help. Thanks!
-Larry
Here's the pcpartpicker permalink to my saved parts list: https://pcpartpicker.com/user/limaalpha0hacii/saved/zTYRBm
-Larry
