Discussion This 4070Ti has a tiny PCB
Ameubius
77
91
Annoying... in another market the full AD104 might have released much cheaper and with a much lower powerlimit :/
(I like fully enabled Die's XD)
@dc443 I like the big FE's (3090/Tie/4080/4090) because this layout would be ideal to utilize the flow through design, a SFX-PSU has the height and SFX-PSU+mini-ITX board the lenght of a big FE:
The threads in the back could be used to secure it and ~ 7,8L would be possible.
My exact thoughts as well, unfortunately they don't sell FEs here in Norway, so some of you must have a go at it... ;P
BTW what CPU/CPU-cooler would you choose?
k0n
96
110
@Ameubius bad availability in Germany as well. And I personally wouldn't have any use for so much performance :/
Just a interesting project and someone paying so much for a graphics card might as well pay 100-200$ for a custom case that is specifically made for it.
CPU-Cooler wise it would be the common 45-49mm limit. Boxed (Laminar RM1/Wraith Stealth), the new BeQuiet LP, Noctua NH-L9,...they all should be OK for 50-65W powerlimit.
Reactions: Ameubius
Ameubius
77
91
I think it would be a mistake to pick a too weak CPU for the 4090, though. At least a 13600k or 5800x3d. Ideally a 7700x or similar, but the power draw from theese CPUs are a bit above 50-65W. Perhaps the black ridge or big shuriken 3, but BR doesn't support AM5 I believe, and BS3 might be too tall?
Reactions: k0n
yeshyyyk
I have an ITX Gigabyte 1080 (the one from the gaming box, no black shroud), might look into moving its cooler onto this if Noobvidia / partners doesn't release a single fan ~200W 4070
wertzius
63
44
@k0n Limiting an AM5 cpu to 65W would still mean 87W power draw - this should not be forgotten. Still a L9a with duct can cope with it.
I like the idea and it mgiht be worth it if a 4070Ti with 16Gb sees the light of the day. The PNy single slot cooler is good enough for 200W - the 4070Ti would still dleiver the majority of its performance with a powerlimit this low.
k0n
96
110
I meant real Watts... so limiting to 65W means setting "PPT" on AM4/5 or "PL" on LGA1700 to 50-65W. From my experience this is achievable with Wraith Stealth(50W)-Pure Rock LP(65W) at up to ~1500RPM.
Reactions: Tyrael
