Everybody at the CES 2025 be like: "its a compact case" - yeah, no shit sherlock, but so is the A3, SAMA IM01, NR200P, Q58, but even the AP201.
So what size is it? Apparently, nearly the same dimensons as the SAMA IM01: 39.1 x 29.4 x 17.9 cm = 20.577 L
Found via this one here:
"Compact" for people building in the NV9, yes. Compact for SFF enthusiasts? NOT SO MUCH.
But the available colors certainly look nice, and seeing its also vented in the front, plus the non-availability of certain similar sized cases - ie. Deepcool - it might be a solid choice for future SFF beginners. Nothing like what Thermaltake claims as "Travel PC case", cause with this size, its probably also gonna weight between 5 - 6 kg, but a nice introduction to SFF nonetheless.
cu, w0lf.
cu, w0lf.
