Has anyone tracked the temps directly under the board (Asrock z270 ITX) I7 7700k no overclock) for example.
I'll be using the slim Nactua setup.
Curious about using a long-ish riser ribbon and looping it under the board and having the pci slot and riser plug just beyond the mount plates.
Think heat is a problem for the riser? (It may well be, I have no idea) :-)
