M11SDV-8C+-LN4F: AMD EPYC 3251, 8 Core, 16 Threads, TDP 50W, (active cooling)
M11SDV-8C-LN4F: AMD EPYC 3251, 8 Core, 16 Threads, TDP 50W, (passive cooling)
M11SDV-8CT-LN4F: AMD EPYC 3201, 8 Core, 8 Threads, TDP 30W, (passive cooling)
M11SDV-4C-LN4F : AMD EPYC 3151, 4 Core, 8 Threads, TDP 45W, (passive cooling)
M11SDV-4CT-LN4F: AMD EPYC 3101, 4 Core, 4 Threads, TDP 35W, (passive cooling)
Details can be reviewed from https://www.supermicro.com/products/nfo/EPYC3000_Embedded.cfm
These are good for VM Hosts, and are great alternatives to Intel Xeon D series.
These 4 DIMM slots supports up to 128GB per module, which will give you 512GB RAM in total.
These boards supports both DC 12V and ATX form factor power supply, which is good for SFF builds. The atx form factor needs an atx 24pin to 4pin adapter to work though.
It has one m2 with PCIe x4 and a PCIe x16 slot. The PCIe x16 slot supports bifurcation natively in the bios, which can run in x16, x8x8, or x4x4x4x4 mode, which is also useful when you do need more PCIe slots.
The downside of this broad is lacking 10G ethernet, which is typical for a server motherboard, and the 10G ethernet port do present on the Xeon D 2000 series boards from Supermicro.
The price is another downside, considering Ryzen chips are relatively cheap. The active cooling version costs about $760, much higher than a typical Ryzen build.
