For two weeks ago, I started a build that I thought I would share with you.
I wanted to create a total black build by spray painting all the parts to give it a theme. I wanted to do this with a RX 470, but the miners did beat me to the punch every time they hit the stores.
This is my first test run just to verify everything was working correctly.
Here I have painted the frame black. This was in silver from the box.
The next images is a bit fast forward, since I didn't take any photos of the actual painting job... Wish I had now while creating this post.
Here we can see the PSU, videocard and backside of the motherboard.
This is from the other side.
I did make a hole in the top plate to fit a slim 120mm fan to suck air out of the case. I did also cover the top by cutting up a ladies thighs made from merino fabric and glued it there. I will have to redo this. Find a better way to do this with more grace.
Here you can see where I am today. I have not painted the heatpipes, but I will when I get the new ones I have ordered. You can also see that the graphic card is not cooled by the case. The computer refused to boot with the heatsink from HDPlex attached to the graphic card. I didn't bother debugging it since I am waiting for an RX 570 mini.
Now let us discuss thermal performance. As you can see I have 4 heatpipes connected to one panel and 4 other to another panel. One would believe that this could handle an Ryzen 1700, but it does not. Aida64 (CPU, FPU, Cache, Memory - all at once) brings the cpu to it knees after 30 minutes - it starts to throttle. This is very, very surprising to me. By my calculations those to panels with 4 heatpipes on each should be able to handle that easily. They don't - as of now.
My research, or should I say debugging, on this is that I have made two huge mistakes.
With my new knowledge, I have contacted Streacom and ordered new heatpipes and heatsinks. I will tame that Ryzen 1700.
Here are my desk:
- Streacom DB4 - black version
- Ryzen 1700
- Biostar X370GTN
- G.Skill 3200Mhz@cl14
- Samsung 960 pro
- MSI RX 550 ITX
- Corsair SFX 600
- HDPlex VGA cooler kit
- HDPlex CPU cooler kit
- The heatpipes is not aligned horizontally. I have come to my attention that this is very important for max performance. I have instead done all of them vertically.
- The bends... It is really hard to make those bends good without the heatpipes collapsing inwards. I have done my best, but there are some points where it looks ok-ish, but after some research I found out that those really hinders performance badly. I read somewhere that with a strait heatpipe carrying 100% and with a perfect 90 degree (molded) bend, it will bring it down to about 93%. I don't remember the math for it, but you added all the degrees of bends and divided that on some value created from the length, diameter and effect from the heatpipe.
Here are my desk:
