Log My (second) Streacom DB4 build
Raiju
44
62
Started working on this build again. Modded the motherboard heatsinks so they can connect to outer heatsink with heatpipes.
msystems
812
1,428
Good to see the db4 still useful. Its arguably the most impressive looking and ambitious case design.
Reactions: Raiju
BaK
985
973
Switzerland
Looks good!
Are you still using the Coollaboratory metal pad(s) as thermal paste for the CPU?
Raiju
44
62
Case was positioned suboptimal for cooling (I miss an angled hdmi cable) but the rest of the panels was off. Heat transfer was real good, the panel became too hot to touch.
Half hour stress cpu goes to 85C (had plateaued for 10 mins) vrm 57C chipset chipset 47C. Rest of temps all ok.
Idle after half hour 36C, all this with ambient temp of 20C.
All in all not bad, too early to tell if cpu is gonna need tweaking for long gaming sessions.
Raiju
44
62
I did not like the 85C, it sometimes can get 20C hotter in the summer here so 85C wont do.
After a lot of tweaking and testing and many clear bios later and bitlocker annoying the crap out of me I got a stable solution.
70C with 4.2 GHz all cores (smt enabled) and finally managed a ram of 3200 Mhz 16-16-16
1 hour test:
1,322
VIC, Australia
Great result, is this 100% passive right now?
I imagine even a small, slow fan that turns on at upper temp-limits would make a HUGE difference to longer sessions.
