A bit bigger follow-up:
I've upgraded the system with
Not that the new motherboard was really needed, but ASRock ITX got really cheap overhere, and I needed some place to put the "old" CPU and GPU into. ASRock ITX is good motherboard, but it's BIOS is super confusing and counter-intuitive... The 3700X was an obvious upgrade choice after almost 3 years, but the real trigger for this upgrade was the fact that PowerColor released ITX variant of 5700! I have to say that this card is a real gem, I could down-volt the thing significantly, and at 100W limit it works flawlessly, at least twice as faster than the "old" RX570.
The upgrade itself was to be pretty smooth, but I had to go extra mile because of the PowerColor 5700 ITX PCB layout, namely the placement of some inductors. I had to file a corner off the HDPLEX GPU heat-sink copper plate so it could fit properly, one inductor as in the way (lower left corner on the picture below):
Anyway, after lots & lots of filing work, thermal paste squeezing & under-volt tuning, everything works pretty good, temps are under check, the overall system feels smooth as silk. In hope I don't have to touch this again in the following 3 years or so...
I have interest in power color 5700 ITX too
Can you share informations of undervolt(GPU voltage, SoC voltage)/ underclock / power limit ?
