Production Sparrow-MQ6 6.8L One-piece aluminum(Sparrow for increased compatibility)
Mackan
315
164
We don't have the black in stock yet, I expect it will be in April.
Last day of April today. Black never got in stock. I don't understand the huge uncertainty in expected stock dates. Is there a scenario here where the black never gets in stock, and the MQ6 ends up out of stock completely, and I end up with no MQ6 at all because I wait for black color?
jaynamics
165
213
California, US
Hello @COOJ, I picked up a used MQ6 case which also included an Enhance ENP-7660B power supply that from this pot I think the seller bought from you since it looks to be modded for modular cabling. Unfortunately, the seller did not include the power supply cables. Do you have any specifics fro this these cables so I can get a set of custom ones created for the power supply. Thank you in advance.
COOJ
206
306
China
名称NAME长度(cm)
MB主板供电线13
cpu供电线23
graphics card显卡供电线25
2.5硬盘供电线25
bouncelinger
Which pcie gen 5 cable would you recommend to use in the mq6? Thanks in advance? Any cable from linkup that fits in this case?
COOJ
206
306
China
Currently, there are no PCIE 5.0 cables with excellent compatibility available on the market. We are developing compatible PCIE 5.0 cables.
zephyrsoul888
Hey Cooj, quick question—do you think the Z-18 might get support for back-connected motherboards? And would you ever consider an optional top handlebar for traveling, plus maybe a larger or even curved glass cover?
Thank you
COOJ
206
306
China
Thank you
There are currently no plans to support back-mounted motherboards, as our manufacturing processes have reached their limits and cannot accommodate larger dimensions.
Reactions: zephyrsoul888
swooc
seems like there is a lot of interest for the mq6. cooj said end of sept when i asked in sept. then later replied with end of oct. going by their track record, i think that means some time late next year :p.
hrh_ginsterbusch
1,111
465
Germany
wp-devil.com
By then, everyone probably has moved to easier available options. I wonder if they realize the harsh irony that its easier to acquire a chronically non-available FormD T1 than their products ..
cu, w0lf.
swooc
to be fair, a few of their products are quite unique. especially the mq series. not many makers offer small volume flex psu cases in a clean and premium design. it's because of this that i will wait for as long as they will take. or until some one makes something similar that will draw my attention away.
plus i think they are a small volume manufacturer from china? so things do take time to make.
COOJ
206
306
China
Yes, we are a small-batch manufacturer based in China.
Another reason for frequent stockouts is our stringent quality standards.
