2022/2/26
We have completed delivery of the first batch and the next batch will be delivered in April.Here are some photos from the purchasers.
cooj.cc
2021/7/1
Added a free new accessory, the halo switch button.
2021/6/22
Two new accessories have been added1. A black metal heat shield for insulating the GPU and PSU from hot air transfer.
2. A bracket for mounting two 7mm thick hard drives.
2021/5/6
My website is now live and you can now book or purchase through the website.https://cooj.cc/
2021/4/27
Uploaded content about MQ6Click to view>>>Sparrow-MQ6 6.8L One-piece aluminum
Sparrow - MQ5
The name comes from a very well-known Chinese saying: ''The sparrow is small, but the five organs are complete''.So here, I named the case after the sparrow.
MQ5 is the model of this case.
Design thinking
The biggest feature of the Sparrow MQ5 is in the overall design thinking; I personally prefer the minimalist style, the starting point of the design is also from the minimalist, reduce the patchwork parts and seams of the chassis, so that the work from the appearance of the feeling of one piece; so from the beginning through continuous polishing, the final only now the unibody design program, complex design and process only for the minimalist look and feel.MQ5 Specifications
| Size | 235mm*210mm *115mm |
| Material | Aluminum alloy |
| Weight | ≈2kg |
| Motherboard specifications | MINI-ITX |
| Power supply specifications | FLEX-1U |
| Cpu cooler height limit | ≤47mm |
| Graphics card length limit | ≤177mm |
| Installable hard drive | 2*2.5 Thickness 7mm |
| Top Fan Specifications | 9015 |
| pci-e extension cable length | 195mm |
MQ5 Introduction
I will upload a separate link for MQ6.
Sample photo
1.Accessories
| Computer cases | MQ5 |
| CPU | R9 3900X |
| Motherboard | ASUS B550I |
| Graphics card | XFX R9 NANO |
| PSU | Enhance ENP 7660B FLEX 600W |
| CPU cooler | Thermalright AXP90 FULL BLACK |
| Top fan | 8010(The official version has been modified to 9015) |
| Hard disk | PM981A 512G + SC308 512G |
| RAM | KLEVV DDR4 16G*2 |
2.Accessories show
3.MQ5 parts display
The shell part is the soul of the MQ5, and the minimalist style and unibody design concept create it.
The aluminum inner ring on both sides is used to fix the magnet, which plays the role of connecting the shell and the side cover.
Magnet fixed with the inlay design, this time the magnet fixed parts with 3D printing production, the surface is very poor, the subsequent injection molding method will be used to produce this small parts.
The side panel is also made of aluminum, 2mm thick, inlaid with iron to adsorb magnets.
Power connector to connect small 1U power supply and chassis
4.MQ5 case assembly
5.MQ5 whole machine installation
Installation of the top fan (I installed the fan in the wrong direction)
Installing the motherboard into the case
Install the power supply parts, the first power supply and power supply parts fixed, installed into the chassis, and then the bottom through the screw fixed
Finally, install the graphics card on
Side panels on both sides are attached by magnets
MQ5 is able to install two 2.5 hard drives (two stacked together), here I install one for a demonstration
Temperature test
CPU temperature test is divided into 2 parts, the first part is not installed side panel, the second part is installed side panelThe test method is a single baking FPU, the length of 10 minutes
The test environment temperature is about 21 degrees
CPU information: R9 3900X voltage 1.1V 3.9G
Without side panel installed
10 minutes temperature: about 86°C
Installation of side panels
10 minutes temperature: about 93°C
Graphics card using FURMARK test, still ten minutes test time
Graphics card model: R9 NANO default voltage
10 minutes temperature: about 77°C
10 minutes temperature: about 79°C
Finally, I hope you like it.
