Moved to a Dan C4-SFX a while back and this guy needs a new home. Looking for $200 plus shipping.
Images:
Original build here for those curious: https://smallformfactor.net/forum/threads/completed-new-sliger-sm550-build-sanity-check.11984/
Images:
- White Sliger SM550 (v1) with two vented side panels.
- Spec sheet: https://www.sliger.com/products/cases/sm550/
- White acrylic window panel
- Ordered but didn't end up using it.
- Gen 3 (included) and Gen 4 (installed) riser cables
- Original order came with the Gen 3, ordered the gen 4 at a later date
- Asetek 645LT 92mm SFF AIO
- With attached Noctua NF-A9x14 PWM chromax.Black.swap fan
- Black anti-vibration pads attached but the other colors are included and can be swapped in if desired.
- Noctua NF-S12A PWM chromax.Black.swap case fan
