Build thread: Project Jolokia - Tiny but potent
Jolokia complete system: $800 + shipping (USA-only)
Original shroud/fans for the GPU will be included.
I messed up the design of the PCIe case cutouts, so on this particular card only the DVI and DP are accessible.
This has the bamboo front, if I can find the original aluminum front I can include it too.
I banged the case into a door while carrying it at one point so there's a dent in the outer shell at the top-rear.
Jolokia case-only: $175 + shipping (USA-only)
There are 4 of these cases available. I think I have 1 or 2 more bamboo fronts that I'll throw in for free if interested.
Internal power cord for a FlexATX PSU will be included. Assembly screws are NOT included (mobo, PSU, GPU, fans, etc.)
NOTE: These are prototype cases and have several annoyances/flaws. The PCIe cutouts are noted above, but additionally here is a non-exhaustive list of other issues:
- Intel Xeon E5-1620 V3 (3.5GHz Quad-Core)
- ASRock X99E-ITX/ac
- Gigabyte GTX 1650 4GB LP (shroud/fans removed)
- 2x16GB Crucial CT16G4XFD824A DDR4 ECC VLP
- Noctua NH-L12 w/ custom mounting brackets for LGA2011 Narrow ILM
- Noctua NF-A12x15 PWM
- 2x Noctua NF-A9x14 PWM
- Samsung 960 EVO 500GB
- FSP FSP500-50FSPT 500W FlexATX
- Outer shell is too tight, and scrapes against the frame when sliding on/off
- One of the motherboard standoffs is slightly mis-positioned
- The case screws are easy to strip the heads
- The powder coating is rough in places, especially the vents on the side panel
- Small scratches and scuffs
