I know in the text of the Imgur album you mentioned that you could fit radiators of a maximum of 150mm in width, but it isn't mentioned the maximum length. There's an indication that the PCIe slot can be up to 327mm in length, but I don't know if that's completely accurate to the radiator slot or if there's some other obstruction (likely) above that limits radiator length.
I suppose instead of asking 20 questions I'll just lay out my challenge: I'm trying to do a full custom loop in the case with a 280mm radiator and struggling on how to fit the pump and res. If indeed you can fit something like this pump/res combo horizontally without interfering with the GPU, then that may be the only option. I see there are tube holes on the back but other than something like the Eiswand (enormous standalone external rad/pump combo unit), I'm not sure how to use them. Can you fit a pump on the outside while having the hoses go through those holes?
Otherwise I'm thinking maybe something like the Eisbaer LT pump/block combo (because the Apogee Drive II is 5mm too tall according to the 55mm cooler height limit) plus a GPU block and a 280mm crossflow radiator at the top, but the Alphacool crossflow radiators (which have top-facing fill ports) are 334mm long so I worry it won't fit.
It's my first time doing an open loop, and so doing it for the first time in a small case probably doesn't help, but any advice you can give (or anyone can give) would be helpful.
There's a total of 328mm of length internal the case, relevant to both GPU and radiator. This was to be able to fit things like EK Vadar 280mm, or 2x 120mm radiators. The Alphcool 280 Crossflow is too big, but the 240 version will fit.
There is space above the GPU for the pump res combo, a lot of room if you do not use a fan on the front of the radiator at top. There should be plenty of airflow through the radiator from the bottom fans.
I will try and get a 3D layout of a few possible custom loops done next week, buried right now.
