What kit do you have? Trident Z? I've got a kit that's about 37mm tall on the way, as well as a PALLAS 120. Curious to know how picky I need to be with the mobo, or if I'll need to grab a different cooler altogether.
Any chance we could get a number for RAM clearance?
This is what it looks like flipped: Hangs over the board.
I could remove it but from what I read, its a pita. My patience level may lead to a broken stick of ram heh. I think it would even hit Corsair LPX sticks. I have some of them I will test with.
We need to come up with a list of all coolers that can be mounted with vertical fins on AM4.
I'll be getting my Pallas 120 in today. I've currently only got one AMD board acting as my main computer, but I'll see if I can borrow my friend's dead X370 board to test cooler fitment across the BS3, Pallas 120 and PH-TC12LS.
@KSliger In the 570/580 what is going to be the max vcard height? Only asking because of how obnoxious the 2080Ti FTW's Hydrocopper waterblock is 158.55mm tall. Might be sticking to air or getting another 2080Ti for it.
AM4 boards are the only ones with potential problems due to the mounting system. There will be at least one orientation that would work for Intel boards I would imagine. Probably only applicable to ITX boards as well.
@KSliger If you mount Noctua NH-L9i With AM4 bracket and it's own fan into the s550, it wouldnt matter as much if the fins are horizontal instead of vertical due to the cooler not completely relying on the case fans only right?
@rjeftw I don't know if this is the be-all-end-all list but it says this on the store page:
* Standard power cable restricts GPU height to 133mm (this prevents some oversized MSI and Zotac cards from being mounted)
** Pigtail power cable mount restricts GPU height to 145mm tall (this allows for taller MSI Gaming and Zotac GPUs)
Looks like even if your RAM was short enough, the overhang if you oriented the cooler that way would interfere with the PSU, wouldn't it?
Bummer.
SM550 arrived this morning. Couldn't wait to put it together!
Looking nice! Any initial temps or performance numbers?
Yea @rjeftw apologies. I was oblivious to the fact you were wondering about the other 2 cases. Im a dork!
