@KSliger Thanks for all of the updates! I've got a preorder in for the 550 and have started to stockpile parts. I'm hoping to use the Pallas cooler mounted on the Strix Z390-I but I'm worried about one part of the fit - and hoping you can confirm a measurement for me.
The Pallas only fits in one orientation and overhangs the edge of the board by about 26mm to the tips of the heat pipes. Is there a gap that wide in the 550 between the motherboard and PSU or should I be looking for a different cooler?
If it fits, it's going to be paired with 2 nf-f12's. I'd be happy to do any testing if others are curious once the case arrives.
That won't work, there's about 1/4" of clearance between motherboard and PSU.
Can you take the IO shroud off of the integrated IO cover? Or would it hit the back of case if rotated around 100 degrees?
If it doesn't work out I'll take it off the supported coolers list, bummer if it doesn't.
I almost forgot, what about ram height for those using aio? I have Corsair Vengeance RGB Pro and it is a bit tall for rgb ram.
Those fit! I used them in the SM550 and SM560 already, and those have the same fit for RAM / AIO Pump / CPU Cool clearance as teh 550 and 560 (55.9mm but recommended 55mm)
EDIT
Little teaser on the SM560!
