@thoughtfix do you think this combo could fit in the front of the case? Between the GPU and the front, with the pump jutting out at the bottom. You'd obviously be limited by GPU length a little...
Hello, I'm thinking of buying a custom cable what's the length on the 24 and cpu cables?Here's his link:
The 24 pin is 175mm end to end with a 3mm taper per row. The CPU and pcie cables are about 260mm off the top of the my headHello, I'm thinking of buying a custom cable what's the length on the 24 and cpu cables?
OOo thanks!The 24 pin is 175mm end to end with a 3mm taper per row. The CPU and pcie cables are about 260mm off the top of the my head
They can be but personally I usually find them unnecessary. The cables that come with the SF750 are already short enough as it is. I had 0 issues with too much cable in the 550 and 560.Ahh thx. looks great, are custom cables the best way to clean up and make space in sffpc builds?
Which cases are included with the QuakeCon coupon?
What?! I ordered the case last week because @KSliger said that the QuakeCon promo wouldn't apply to the SM570/580's. C'mon
IDK, maybe he changed his mind? You can always reach out to them,see if they can give you a partial refund? Worst thing that'll happen is they say no
Same hereRight, yeah. I just emailed them. I was actually emailing them a couple of times now, without any response, regarding my order
I’m not sure there will be enough space. You got about 2 in from the center spine to the outside of the case and another 2 in from the end of a 10.5 in GPU to the front wall of the case. That reservoir is over 3 inches wide so idk how you’d get it mounted in there without some serious creativity.
Right now I’m trying to find something (maybe custom made) that can fit in the front panel of the case where the SATA drive would go. There’s 22mm of space up there which no readily available res seems to fit unfortunately.
Literally joined just to respond to this lol.Yeah, I know they're all busy with all the orders that came in but it's hurting their business. KSliger assured me that there won't be any problems with the case being delivered to the hotel where I'm staying on or before August 2. I'm not from the US and will be here only until next week (August 3 morning flight) so I'm starting to worry about the timeline.
Is there a chance of a push-pull configuration (on an AIO) working inside the SM580? I would assume it’s not likely, but the thought had crossed my mind.
