Hi Aibohphobia,
thank you for your reviews of SilverStone SX700-LPT and Lian Li PE-750, I like the focus on the noise part, that’s the important part to me!
I’m planning to build a rig with a 6700K + GTX 1080 in a DAN A4 case, so from the power side, the Corsair SF450 would be sufficient for me.
But is has the smaller fan, so I wonder, if the SX700-LPT might be the better choice, when it comes to noise:
The smaller fan would probably spin faster under high load?
Maybe the fan of the SX700 will stay longer off?
Bearing noises?
What do you think, what is your personal opinion in terms noise?
In this case, price or power efficiency is not relevant to me, only noise J, so what would you choose?
Bearing noises?
