Power Supply SilverStone Cable Compatibility
XCOM-SFF
29
Hello everyone
Currently running a SilverStone SFX-L 700W PSU, however as I have changed the case I am using for the build I was wondering if the SilverStone cables would be compatible with another full size PSU, any recommendations?
I am using these custom cables
Thanks guys
Ceros_X
747
660
US
Hello everyone
Thanks guys
This chart lists all the compatible PSU series/models for the ST-Series cables you are using: (the very bottom of the list) https://cablemod.com/compatibility/
EdZ
Virtual Realist
May 11, 2015
1,577
2,108
UK
Silverstone advertise all their modular PSU cables as being cross-compatible for any of their PSUs manufactured since 2009, so any custom cable with the same pinout should be too.
4,796
All their cables are interchangeable except for some of the Nightjar fanless units that were made by Seasonic. The upcoming SX800-LTI has an extra 4-pins on the 24-pin for voltage regulation but it should work without it.
XCOM-SFF
29
Thanks for the reply everyone - I think I already know the answer to this but do you think the cables are compatible with another PSU Brand, such as Corsair or EVGA. ]
Thank You
