Cooling Sharkoon QB One cooler height
Lung
The Sharkoon QB ONe lists the max cooler height for CPUs as 150mm. Does anyone know if this includes the space taken up by the fan mounted on the top of the case (15mm i think)? Or is it 150mm plus the top fan? It makes quite a difference to which coolers will fit. I contacted Sharkoon ages ago to find out but never got a response.
atsf
Hi! I have measured 13,5 cm, from the top of AMD stealth heatsink (I my ruler haver a dead height of ~1mm):
cwspellowe
My old case was a QB One. I had a Cryorig H7 Quad Lumi and it was at the absolute limit of what could be squeezed in without case fans. If you wanted to use a case fan that would impact your cooler height, yes
