Hello,
I am assembling a PC in the Sharkoon QB One case and I would like to be sure to have the best possible aircooling flow.
Can you comment on this drawing?
I have a Noctua NH-U9S (red in the diagram) with two 90mm fans (grey and yellow). I have two 120mm fans (orange and green) for the top and one 80mm for the back (violet).
The way I am planning to orient the airflow is represented by the blue arrows. So the top fans will suyck air into the case. The grey one will push air into the cooler while the yellow one will pull air out of it and the violet will pull air out of the case. The PSU is in black color with the fan on the bottom matching another opening. Please note there are ventilation holes on front, both sides and behind the 80mm fan.
Thank you.
Thank you.
