Yes, I'd like to get rid of the 'maybe' as I'm looking at this as an option to proceed an upgrade with
I do have the G.Skill, which is talked about here. Prior to finding sff and becoming a member of it's community
Theese are the 3200 XMP Modules at 18-18-18-43 / 2x 8GB.
(Able to lower to 16-17-17-34, still staying at 1.20V DDR, running Ryzen 2400G - but I assume it will
impove given the upgraded memory controller of the 4000G Series. On the other hand, I'm able to stay @XMPTimings and leverage the Bandwidth to like 3333-3466MHz but the APU becomes unstable. So the memory should be good enough)
There is no good guide for SO-DIMM modules and the Chips soldered on them.
This particular G.Skill is "H5AN8G8NCJR-UHC", recognized as Hynix, "8 Gb C-die (Alius / 18 nm) / 1 die "
The G.Skill 3000 XMP Modules use also the same Hynicx DIEs.
You may also check
this post from Weekly_Cow using Samsung C-DIEs on 2666MHz rated modules. Clear success. 3600@CL18 would be amaizing.
@Weekly_Cow speaking of you, may I ask you about your memory timings @3600MHz? Thank you
(CL18-22-22-42?)
PS: Some fun facts. I used to read somewhere that the memory controller for the 2000G Series was not made by AMD.
The engineering was outsourced to AMD's partner, so they can stay focus on Vega and Cores and InfinityFabric. But I can not find this info anymore.
Im running some inexpensive Crucial memory. XMP 3200 that I just set to 3400 in the BIOS and runs without issue for me. Im not much of a tinkerer so if it works I leave it if not I just leave it stock.
