Cooling [SFF Network] Passive Cooling - An Experiment
CC Ricers
2,235
2,558
My idea of passively cooling a GTX 950 now looks more feasible in SFF with MSI's 75w models.
My idea is to use a large extruded heatsink that is shallow but covers the entire surface area of the entire side of the case. The design is something like Streacom's NC2 but vertically oriented (so heat fins point sideways) and larger. The CPU would be cooled separately, using a low-profile CPU cooler with intake on the opposite side.
The most time consuming part would be cutting down the heatsink to have it mount well on the GPU chip while also not interfering with the taller components such as capacitors.
Reactions: confusis
jtd871
1,165
851
Indiana, US
Black is the best thermal body in terms of being a absorber or emitter - so even though a layer may be added to make the cooler the darker colour, the benefits of the heat emission may outweigh the losses from adding a layer of plating/paint.
Dear heatsink manufacturers: please get on with the R&D into copper sinks coated with carbon nanotubes.
EdZ
Virtual Realist
May 11, 2015
1,577
2,108
UK
Surface colour has an effect on radiant heat emissions, but CPU heatsinks are so cold (compared to, say, molten salts or space-based fission reactors) that it is likely the only effect a coloured coating would have is the small thermal resistance of the coating itself to conductive heat transfer with air.
A textured coating could have interesting effects, but then you start to get into turbulent vs. laminar flow effects, and you dive down a CFD rabbit-hole and start proscribing fans with tuned CFM performance and stacked-tube flow laminisers.
Reactions: Honegod
7,955
Auckland, New Zealand
That's a good point (albeit with so many big words o.o ) In saying that, would a black nickel plating have a negative effect on aluminium fins?
QinX
541
374
The Netherlands
In theory it should, you are adding and extra layer that has a thermal resistance. In practice you won't see any perceivable difference.
Stevo_
449
304
SoCal
The experiment showed more than anything the sub-optimal orientation of the heat pipes dominates performance. When I had my AXP100 horizontal(optimal) in my Node304 it cooled much better than with motherboard in the vertical position of my L2, heat pipes running left-right. For top-down cooler Noctua lists on their site the one orientation to avoid when the mobo is vertical is with heat pipe bends at the top, pretty much defeats vapor cooling.
775
759
There may be a very slight drop from the intramaterial conductivity, but with a void-free plating, it should be minimal. I belive they were wondering about additional gains improving the emissivity from black-body radiation. Radiation isn't the best means by which to remove heat, but keep in mind that electronics in low earth orbit (LEO) and outer space are cooled exclusively by it (there can be intermediary devices, but it is radiated away at some point).
Cuzza
LOSIAS
Jul 15, 2015
38
39
New Zealand
Radiation really must be negligible, otherwise everyone would have been making their heatsinks black for years.
I would like to see some testing of methods to increase convection. You should make up some cardboard shrouds or something.
Kooki
129
56
I see you finally got the new motherboard! Cheers :cool:
Quick question: Does the Cryorig C7 fit nicely this time around on this mobo?
