SFF.Network [SFF Network] Enermax reveals the Steelwing mATX case
Tom's Hardware has some details of the Enermax Steelwing microATX case they teased last month. It's an aluminum microATX case with a glass side panel and support for 260mm long video cards. MSRP is $140 and will hopefully be available in July.
The picture is low resolution and has a reflection but from what I can tell this is only a 3-slot case. So running two graphics cards will require water cooling and will be limited to cards that either come with the IO in a single-slot configuration or will require modding to remove the DVI connector that would be in the way on so many modern cards. It's hard to tell from the picture but there may be room though to cut a fourth slot into the case to allow normal double-slot cards. If there is room though, I can't comprehend why they wouldn't include it already on what's ostensibly a microATX case.
Read more here.
5,938
4,951
I was suspicious when I saw "Enermax" and "case" in the same sentence, nice to have the Segotep case become available outside of Asia.
