When doing future reviews on CPU heatsink coolers, would you please include these (if hardware setup allows):-
a. testing different orientations of the heatsink to investigate the effects of gravity. (I note that some brands (eg Thermalright) advertise some of their coolers having Anti-gravity Effect heatpipes.)
b. comment on the (positive) impact on the cooling of the M.2 SSD (which usually sits right next to the CPU socket) due to the airflow of the CPU heatsink fan.
a. I do not have any particular Thermalright in mind. And, to this regard, I suppose you will also test (full size or mini) GPUs as well. As vertically oriented cases are getting more popular, this aspect should also be useful.A. This is a good point, and the orientation testing is definitely something that's been on my mind. Our current test bench can't really be used to do it. Eventually, when we get a new test bench, I'll add it to the test. In the meantime, I'll look into possibly doing an article covering the issue. Is there a particular Termalright unit you have in mind?
b. This is actually more difficult then it sounds. Any airflow over an M.2 will help, however it's very motherboard dependent. Some have heatsinks, some are double stacked, and some have fans. Moreover, case air flow (or lack there off) will play substantial part to air moving across the board and subsequently to the temps of the M.2. It ends up becoming a measure more of the motherboard and case than it does the CPU cooler. It is something I plan to include in motherboard and case reviews though. I can do a downdraft vs tower vs AIO comparison though.
Even though the only exhaust is the PSU, but the cabin is likely going to have a very strong positive pressure, thus a fairly good portion of those hot internal air should go through, say, the top vented panel. PSU should survive being toasted.Setting up our PSU murder box…
7820X
2X 770s in SLI
Only exhaust is the PSU.
cabling? Shove it in.
But I bet you have a much better voice than Linus'.Damn Linus for posting the Sugo 16 video LOL.
Now I have to get ours out early. I’m not using an AIO though.
But I bet you have a much better voice than Linus'.![]()
I have this motherboard and I am sure many people are interested in which coolers and AIOs you are able to fit.
I’ll post up something on it today.I have this motherboard and I am sure many people are interested in which coolers and AIOs you are able to fit.
