Sea-Damage's Sesto Elemento One
Testifier
55
103
First SFF build.
Even though I said build, it's just mostly moving the internal of an X51 with some upgrades.
Case: SE One by Sea-Damage, it's a case made completely from carbon fiber
X51's parts: i7 4790, 1155 Motherboard, 16GB RAM
PSU: Corsair SF600
GPU: R9 390x
Storage: some cheap SSD
parts that I'm gonna stuff in the case
R9 390x, enough for my gaming on the go
my total disaster cable management
stuffing done!
Testifier
55
103
Thanks, everyone, first SFF build and I'm sure I screwed up a lot
@Signa I got it from the same Taobao link posted.
A few things about this case:
- The carbon fiber sheets are incredibly light and sturdy, with the exception of the side panels because they're too thin. However, you won't notice that one everything is stuffed into the case.
- Carbon fiber is conductive, so people who have GPU without backplate should worry about that
- Only compatible with SFX PSU, not SFX-L. Probably not a problem because everyone is going for the SF600 for this type of build anyway
- Two 2.5 drives can be installed, no 3.5
- You can have the custom engrave on the top piece like mine engraved with character 海
- Choosing between having a tail (the extension cord from the PSU hanging out of the case) or no tail (the cord is fixed to the case). The latter choice will limit the GPU height and make it harder to install the GPU a little bit
- It's better to ask them for extra dust filters for the top and bottom if you feel like it's too breezy
rahl07
33
24
This is a bad-ass case; I really like your build. I was all jazzed until I realized my yen converter was going from JY to USD (About 16 bucks) instead of CY to USD (about 250 bucks). Still adding it to the list of potential cases for next year when I finally cough up the funds.
