Read the latest update here! -- Draft 3 - 12.9 liter case
Hi! I am looking for advice on this case I am designing.
My first PC build is almost 10 years old and is still good enough for my use case. I have upgraded the gfx card a couple of years ago, but that's it.
My problem is that I built the PC in a huge 52 liter case and it is taking a lot of space in my apartment.
So now I want to go small, but I don't want to spend a lot of money on downsizing.
My current build specs:
However it is very hard to find a mini-itx MB with AM3 socket. So I would likely have to buy a new CPU as well which again would lead me to buy DDR4 ram and so on.
Besides that most mini-itx cases only support smaller PSU sizes, so I would likely have to buy that as well.
It would basically mean replacing most of my computer with new parts.
The best solution I have found that would not mean making a custom case is buying a Raijintek Thetis case. However that case is almost 28 liter.
I want to go smaller than that. So I figured I would just design my own case instead...
Draft 2 - 12.9 liter case
Thank you for reading!
- Cooler Master 690 case
- evo 212 cpu cooler
- AMD Phenom II X4 965 CPU
- GA-790XTA-UD4 Motherboard
- 12 GB DDR3 Ram
- GTX 960 (MSI) 4GB
- Corsair TX 950 W PSU (yes it is way overpowered for my needs, lol)
- 2.5" 80 GB intel x25-m SSD
- 3.5" 1 TB WD black 7200 rpm
- 3.5" 4 TB WD blue 5400 rpm
So here is my design so far. The IO is on the left and the power plug is on top of the case, which might sound like a weird design choice. But right now I am more interested in size than aesthetics. The case will not be covered in hexagon pattern, it's just there as a visual guide.
12.6 liter case. 5 mm walls:
IO on the left and power cable on top. Kinda weird, but necessary to keep it small:
CPU fan up to 80 mm height:
Space for cable management between gfx card and MB:
Space for up to 3 x 3.5 drives:
Parts are from my first PC build that I did in a 52 liter case, 10 years ago.
I bought the GFX card and 4 tb HDD a couple of years ago.
I don't own the noctua CPU fan, but that's the fan I would put in this case:
The cables from the PSU go underneath the gfx card and to the left of the HDDs:
Please give me advice on this case design!
Things I am not sure about:
- Airflow
- Where should air holes in the case be?
- Do I need some kind of additonal case fan?
- Case material (needs to be laser cutter compatible and relatively cheap)
- Acrylic?
- MDF?
