CPU RX6800 XT & Enhance 7660B 600W PSU
SFFManiac07
So I am planning to get a 6800XT for my rig, currently using a 1660Ti, my rig is powered by an Enhance 7660 PSU, so my question is, is it possible to run a 6800Xt with this PSU?
Firebear
35
Depends on your CPU and if you have many harddrives, fans and such. If the PSU is platinum rated then it could handle it.
SFFManiac07
Using a 3600 with a 2TB Nvme, a 120mm AIO and another 80mm fan, also the 7660B is platinum rated yes, but the reason I asked is cuz there is only one 6+2 cable coming out of the PSU with another 6+2 plug on the same cable, so is that okay?
BakaBazooka
Could try this 700w 7760B PSU, if you can order it. Got people running it with a 9600KF + 3070 / 3900X+2060+64GB ram+2xSN750s.
If you are going to swap out the stock fan for a Noctua A4x20, for silence, a safe limit would be -100W from its max. As it doesn't blow too much air.
