Log Revocases TIPIO1 build with GTX 4060 and 12th gen
milesvw
132
95
This Log will detail fitting a 4060 Low Profile and a JW H610i-PIO motherboard in a Revocses TIPIO1 "1.9L" case (Well, I currently have 8mm standoffs under the lid, so add some CM²).
Currently rocking an i5 12500t and 2x16GB 3200Mt/s DDR4. Shouldn't be much of a bottleneck at 1440p, and the bottleneck keeps the power consimption lower anyway.
Todo: cut more cooling slots for the middle GPU fan. Or use an ITX lid for the CPU side and mesh for the GPU side.
https://smallformfactor.net/forum/t...-tipio1-1-9l-thin-itx-pio-console-case.16711/
Shortened up the power button lead and a modular PCIe cable I got on Amazon a while back. I'm loving the power the crimpers and terminals give you.
I have clearanced the ports after this, I only lost 2 USB and the HDMI while retaining a lot of strength. (At least with my TVs and Monitors the HDMI signal constantly drops out, it's useless)
*And yes, the case is literally under the GPU's plastic fan shroud, but it fits!
