Log "BR1KY the Brickless" - RTX 4060 & Ryzen 7 sub 1.3L build - aka "Project MULT1PL4"
ozkf
Amazing work!
@REVOCCASES did you have a chance to measure GEM10 board? Or it's literally 10x10 cm?
And could you clarify what CPu cooler used? And maybe a height of this board with this cooler.
Will be appreciated.
REVOCCASES
2,256
3,694
Germany / HK
www.revoccases.com
Amazing work!
I made a dummy 3D file for the board, see attached. Hope this helps...
CPU cooler is stock, works pretty good so no need to replace...
  • GEM10dummy#.zip
Reactions: ozkf and rfarmer
ozkf
Is this CPU cooler removable? I'm thinking to try AOOSTAR GEM10 with 4070 but not sure stock cooler will handle CPU heat in that case
So maybe I could use som bigger cooler instead. Or it's a bad idea to pair GEM10 with 4070, how do you whink?
REVOCCASES
2,256
3,694
Germany / HK
www.revoccases.com
Stock cooler is removable but I haven't tried since I found it more than sufficient. If you want to use another cooler anyways, keep in mind it needs modding to fit as it's not a standard socket...
Sure you can pair it with a 4070 ;) are you going the route via Oculink or M.2?
ozkf
Hi, @REVOCCASES
Can you please share the exact model of M.2 riser?
And what is the CPU temps idle/gaming? A bit off top but does GEM10 BIOS provides an option to undervolt the CPU? Or it could be done via Ryzen Master?
REVOCCASES
2,256
3,694
Germany / HK
www.revoccases.com
Hi, @REVOCCASES
Sorry, I can't find the link right now. It was one of their PCIe Gen4 M.2 adapters.
Temps are 30 to 40 in idle, around 70 on load with balanced fan settings.
Didn't check voltage settings or Ryzen Master, I just set TDP to 45W in BIOS, this works good enough for me.
Reactions: ozkf
Sicaris
130
74
How does the internal power connection work here? Is there an internal power header on the gem10 board or do you route a cable outside to the barrel connector?
