Just curious if SFFlabs (or someone else) sells the Ncase m1 V6 internal power cord in reverse from the stock one?
My build has the PSU (SF600 platinum) turned against the front of the case, so the powercord attaches on the right side of the case. This is doable with a little planning as you use to bend the power cable down since it won't clear the tab for the side panel. It's just a really tight bend. I figured they would offer a cord with a different orientation to the right so you don't have to bend the cable.
Thanks
Thanks
