Im not able to find the height clearance. Would the corsair vengeance RGB pro fit?
M mcct_93 Efficiency Noob Original poster Aug 20, 2019 5 0 Sep 16, 2019 #1 Im not able to find the height clearance. Would the corsair vengeance RGB pro fit?
Choidebu "Banned" Aug 16, 2017 1,199 1,205 Sep 17, 2019 #2 Should be the same as cpu cooler height limit, no? 45mm, or 'right up against the side panel' 47mm. Don't worry about ram height unless you plan on using oversized cpu coolers like black ridge etc
