Raijintek, famous for their Metis SFF case, has created a new generation of this SFF stalwart – the Metis Evo..
From Raijintek;
“Design Art in its best by RAIJINTEK – New series of SFF chassis. The METIS EVO case is designed to fulfill a smallest case built with Ultra high air flow to solve all thermal issue of SFF chassis nowadays, can even install 200mm fan at front & 120mm/140mm/200mm AIO and DIY water-cooling. METIS EVO case supports up to Mini-ITX motherboard, able to install an ultra-high air flow 200mm at front (option), also can install 120/140/200mm radiator at front too (Optional), a 120 + 92mm fan optional at bottom, 2*9225 at rear (Option). METIS EVO Superior features includes elegant Sand Blasting on Aluminum, 3.5”*2 HDD + 2.5”*2 HDD/SSD, VGA card length of 280mm (without radiator280mm ; up to 220mm with 30mm thickness radiator installed) can fit most powerful GTX 1080Ti Mini or up to RTX 2080Ti twin fan video card, tool-free for easy installation, ATX /SFX PSU...
Continue reading...
7,411
From Raijintek;
Continue reading...
couchpotato
31
24
Raijintek should dump the ATX PSU and shrink the case to less than 20L to be a true itx case. At 22.4L, they better make it a M-ATX case. And the proportion of the case with tempered glass panel make it looks like a microwave oven. Perfect for sitting on the kitchen table.
Disappointed.
5,938
4,951
I'm happy perforated panels are becoming a thing again, the trend of suffocating all sides of a case with slabs of glass or metal without any openings is good to create a hotbox but not a quiet and performing PC case.
The-Alchemist-404
28
I'm happy too, and not only for that, having more cases with 200mm fan and rad support are comming back hopefully they form a standar for them
