Cooling Radiator Screws for slim fans.
Ragsters
54
I am using the Nactua NF-A9x14 PWM fans with a radiator in my Ncase M1. Where can I get screws that accommodate 14mm fans instead of the typical 25mm fan?
rosinbole
221
222
www.instagram.com
Depends on what kind of radiator it is, what screws you need.
Usually you can find all kinds of screws on amazon or ebay... actually you can find pretty much every type of screw ever made in pretty much every online "supermarket"... :)
You just have to know the length and the type of thread!
Thestarkiller32
152
102
There are 2 types of Screws:
UNC 6-32
M3
Thowes are the most common ones and if they are to long, get a Metalsaw in the hardware store or ask someone.
5,949
4,954
Step 1.
Determine the thread and screw size. Enough guides online (example)
Step 2.
Find replacement screws either the right size or ones you can shorten. If you know what screw size and thread it has, you can visit the hardware store.
Step 3.
If your replacement screws are too long or you can't find replacements and want to sacrifice your original screws (I recommend finding replacements), you can shorten them properly with this kind of screw/wire stripper pliers:
Usually they come in Metric (M3) or Imperial (6-32), rarely both. Ideally use a matching nut, which you wind for enough down the screw so it can go in the pliers and after stripping you can remove it, possibly fixing a thread issue caused by cutting it.
jaruri
25
51
If you have hardware stores nearby I would go and check their screw bins. I needed different rad screws for my 15mm thick fans as well as extra long ones for an externally mounted fan with added filter. The first store I went to had all the screws that I needed. Costed me less than 10 cents per screw, which was much cheaper than trying to get them online
Ragsters
54
Thanks man! I figured that a 0.75 in long screw is probably what I need. I have a Home Deport near me so Ill give it a try.
Reactions: Blubbie21
