Hi again all!
I have a bit of a dilemma, all of the components have arrived for my first SFF build apart from the Noctua fans i ordered, the A12x15 PWM Chromax x2 and A9x14 PWM Chromax. Today they contacted me and said they are going to refund because there has been an issue with the delivery and now the items are out of stock. Nightmare... but now i need to try source replacements.
Going into the NCase M1 is a NZXT Kraken X52 and a Nvidia ASUS 2070 super 2.7 slot. I believe this limits me to 15mm depth fans on the bottom and i am likely limited with space for the rear fan also.
My question is what is the next best thing to a Noctua in terms of slim fans? I have had a look around but trying to find something that is decent and 15mm appears to be quite difficult.
Is there any chance a 25mm depth fan will fit? That would make life a lot easier.
Whats the max depth 90mm fan i can fit with the AIO cooler in the way?
Any help will be much appreciated, itching to get this put together.
