Curious of 2 things -
1. The case I'm going to use is the Phanteks Evolv ITX. If anyone has this case I was curious if the bottem LED can change colors? I'd like to set it to red. The caseking review of the white tempered glass edition says it's capable of changing colors, but everywhere else says it just glows white. Can't post link yet but easy to find on Google. Maybe it only changes on the tempered glass version? (I plan on getting the black tempered glass edition). Also what color is the top power button LED (if there is one)?
2. Kind of confused on what to do with fans. I'm going to use a 240mm water cooler with 2 fans. The Mobo I'm using has one CPU fan slot, 1 case fan slot, and 1 AIO pump slot. I will plug the pump into the AIO slot. How should I go about hooking up the 2 rad fans? Should I use a splitter in the CPU fan slot? What about case fans (there will be 2 or 3 case fans)?
Appreciation in advance! Glad to be a part of the forum.
-Dan
-Dan
