Many hours of YouTube research brought me here but not without noob mistakes in planning and execution.
I started with a MB(A320) that didn't fit the case (Cougar QBX), and the second MB (ROG 470-I gaming) didn't run the CPU (Ryzen 3400G) without a bios update from Micro Center).
What a start!
https://photos.google.com/album/AF1.../AF1QipPHljeLK80ZsIJZ8mEkXAjRrlM2aaowMI0C1FPm
Time to put it together.
Yes, I rotated the AMD logo fan cover. Does that count as my first Mod?
https://photos.google.com/album/AF1.../AF1QipO3-cG3nZF2s7lsv7o3vHQAg7Wgpoidw18lo6Po
Vega graphics good but not enough, I needed a 2080 Ti, but I could afford a used MSI GeForce GTX 1070 Gaming X.
Bent the hell out of the case to fit it in. And because of the height of the GPU the power cables stuck out too far so I couldn't put the side cover back on.
https://lh3.googleusercontent.com/p...WHJjX4rzauEZSpsN8h-g=w1786-h893-no?authuser=0
Got a great ebay deal on a used Ryzen 3800x ($215). But will it work? YES!
Add used 16gb G.SKILL TRIDENT Z 3600 C16 and right angle power cable adapters so I can now close the side cover snugly against the cables.
Only this Noob would buy one of the only GPUs that doesn't fit this case.
Time for the dremel and black tape to cover MCI logo (too much RGB logo puke).
3800x thermals too high. So Let's pack it with fans.
https://photos.google.com/share/AF1...?key=bUstQWlWbFBqZ0Y1dFpVNDdoMDlUeE9oV0dEa3NB
This case will fit 2-120mm exhaust fans in the top but the PSU power plug goes the wrong way.
Buy a plug adapter that goes the other way, shave it down till it fits. I'm getting the hang of this dremel thing.
Success!
Finished....for now.....thermals under load 79 degrees. Cinebench 20 score OC 5170. I love this machine.
For those of you who are still reading this, thank you for your comments, thoughts, and ideas good and not so good ?.
Updated Technical recap:
MB: Asus ROG STRIX X470-I GAMING
CPU: RYZEN 7 3800X
GPU: MSI GeForce GTX 1070 Gaming X
SSD: SAMSUNG 970 EVO PLUS 500GB 3.0 (NVME)
SSD: ADATA SX6000LPN 1T NVMe
MEM: G.SKILL TRIDENT Z 3600 C16 16 GB (2x8GB)
PSU: FSP Dagger 600W 80 Plus Gold Certified Full Modular Power Supply
5 NOCTUA FANS:
(2x120mm) NF-A12x15 PWM, Premium Quiet Slim Fan, 4-Pin
(1x80mm) NF-R8 redux-1800 PWM, 4-Pin, High Performance Cooling Fan, 1800 RPM
(2x120mm) NF-P12 redux-1700 PWM, High Performance Cooling Fan, 4-Pin, 1700 RPM
(1x90mm) Pre Installed rear fan
-Robert
What a start!
Google Photos
photos.google.com
Google Photos
photos.google.com
Google Photos
photos.google.com
Success!
Google Photos
photos.google.com
CPU: RYZEN 7 3800X
5 NOCTUA FANS:
-Robert
