Project Z10P - SFF render server
3feetcat
31
218
I wrote this post for 2 hours and the system told me I need to log in again and that's what I did. Then the forum doesn't have autosave, so all my paragraphs are gone. I am not frustrated, not at all. It's just I don't want to retype everything again.
Z10PH-D16, with D9L, SFX and low profile graphic card.
Project Z10P - blade server motherboard
Size 6.85*18inch. about 2.5x size of an normal ITX.
jtd871
1,166
851
@3feetcat
I feel your pain. Maybe next time compose in word processing software before copying to post when you have a lot to say? That way you also can save a local copy for your reference.
5,937
4,951
This kind of board layout expects the airflow to happen over the entire length of the longest dimension to cool other components. Have you found this to be an issue in this concept ?
3feetcat
31
218
@3feetcat
Emm. Good point. I'll try that next time.
Love it. The half-SSI form factor is insanity - I built with a dual LGA771 one years ago!
Did you run into any problem with this kind of motherboard? Sometimes this motherboard show ram warnings, I even bought an extra motherboard but the problem still exists.
as far as I know, no such problems. Thanks for raising this question, I will do the tests after i receive the prototypes. :)
Reactions: Phuncz and confusis
7,408
@3feetcat No problems at all. Bear in mind that this is server hardware and thus it can be really, really fussy when it comes to hardware though! All part of the fun :)
owliwar
Lazer3D
Apr 7, 2017
586
1,082
sorry for your loss (of text)
this looks insane!!
I'd love to know more when you have the patience to write some more about it.
never knew this size of board existed.... this is so nice!
Reactions: rosinbole
eggDK
78
50
Subscribed, only because of the insanity of this build XD
You kinda have to update the OP so we get to know what this beast will be working with when it's done. Title says render server.. Rendering what?
3feetcat
31
218
sure i'll keep in mind :)
lol. thanks
keyshot meanly.
here is my 3d model library for computer hardware: https://grabcad.com/kevin.yu-7
u might be interested.
chris11d7
Can anyone here confirm that this board works standalone, and does not require to be plugged in to a proprietary matrix? I am looking into building something similar to this using this motherboard, but am worried about compatibility.. It's hard to believe it can run off of just the 24 pin motherboard power, with no 8 pin CPU power? Am I missing something?
3feetcat
31
218
YES, this board works alone and you still get all the functions.
This specific board I am using requires a 20pin customized connector. However you can find the pinout in the user manual, so if you know how to customize cables, then it won't be a problem.
