Hey all!
Today I'm going to introduce the Project Skuld!
I kept thinking why no one does a case that values a bit more the horizontal space? With the exception of Corsair they aren't very space efficient and usually rather large cumbersome cases.
We also face the issue that sometimes trying to achieve the magic volume number we forget that we need some leg room for expansion, and sometimes those limitations were put offs to such compelling and amazing cases that our community has and will continue to provide.
Still there is, I believe, a niche of people that value a lot their desk space, and thus I set forth some goals for this project:
- Its design should fit in the office and in the living room and everywhere you want
- Needs to have a small horizontal footprint
- Has to accommodate a larger selection of CPU cooling
- Will accommodate larger 10,5" GPUs
- Will offer the great air cooling capabilities
- Has to have enough storage expansion options
- PSU needs to be commonly available, there are markets that are less serviced than others
And I think, I have met every single goal that I set forth.
So here is Project Skuld.
PSU, is one piece of hardware that we usually maintain for a few years! And this needs to be readily available! So while I really enjoy the space savings that other options offer, TFX for example isn't even available in my country. So SFX was the choice.
While I want faster and better storage in the form of NVMe, there are some drawbacks to that option. I took a peak in several mITX motherboards and saw a common trend 4x SATA ports. I wondered why not provide the storage that some people may need? And thus there are 4x 2,5" slots for you to enjoy some data security on your life, and yes 2x support larger 15mm thick drives!
Cooling is always something that we worry about in our SFF builds, is it going to drown in heat, will I be able to overclock, how will this affect the lifespan of my components? What she offers is indeed great cooling capabilities with its convection based design aided with 3x 92mm slim fans. Not only that there is space for up to 80mm height coolers in there as well. And if you still want a forth fan may be added if you want to forgo SFX!
Larger GPUs have always been an issue with the SFF community, and we struggled for a long time to get something that is reasonably powered in an ITX form factor! While the GTX 1070 almost matches that, we are still out of the enthusiast market with the GTX 1080 upwards not available at less than 10,5". The choice for me was obvious I have to provide that.
I always thought that we lacked more materials in the PC construction, its always metal and plastic. Those handmade cases with different textures and materials is what I think needs to be put forth. So I inserted that, wood and metal working together to bring some minimalist design to you.
One thing that I always kept wondering is how can I improve on the designs that are offered here and elsewhere. Truly its hard. We have Cerberus with its infinity vents, and great design that brought forth the space efficiency, we have the A4 SFX, the Sentry, the S4 mini... Well, as you can see its a daunting task to match those guys.
So what I can make to stand out, to make it easy to work and a joy to fiddle with your components in a 9.8L case?
I bring you Yggdrasil, the structure.
A case needs to have a structure, it can be part of the case, as is in the S4 mini and sentry for example, or it can be a separate component where you attach your panels and components to it, in the case of the A4 SFX, Cerberus and really most of the other cases there.
Both have positive points and drawbacks, specially acute is usually that they are hard to work on smaller frames, and after we are done, we are relieved to not fiddle with it again in some months or years.
I have worked on IT for a long time now, and sincerely, there is one thing that enterprise class hardware usually has... Easy of maintenance.
This was the whole idea. I wanted to provide an easy case to work with, and thus I thought of a very open frame that we build and slide you case afterwards. Simple!
So here are the numbers of Project Skuld:
- Dimensions: 350mm (H) 140mm (W) 200mm (L) (external measumerement, with feet)
- Volume: 9,8L
- Storage: 4x SATA 2,5" disks, 2x up to 15mm
- GPU: up to 10,5" with the lower fan in place 286mm without it
- CPU Cooler height up to 80mm
- Case fan capacity: 3x with SFX PSU, 4x if using external solution or smaller PSU
- Material: Stainless Steel and Wood
- Video out: 2x HDMI and 1x Display Port
I hope you guys like it!
Here are a couple of pics:
Doubts, questions, suggestions, just post away! I want to hear from you!
![](/forum/proxy.php?image=http%3A%2F%2Fi.imgur.com%2FoEIoq7P.png&hash=afbf2eeaa110361436fdc13f422d761b)
![](/forum/proxy.php?image=http%3A%2F%2Fi.imgur.com%2FO10fw55.png&hash=28a25f04cd23c0bc6967c2d2b36ae946)
![](/forum/proxy.php?image=http%3A%2F%2Fi.imgur.com%2Fupr5Nfi.gif&hash=26b44a8091d93e40f33d931872750439)
- Volume: 9,8L
![](/forum/proxy.php?image=http%3A%2F%2Fi.imgur.com%2F14mHrHT.png&hash=06d60d4b0b13c659bb1829a20475d2a8)
![](/forum/proxy.php?image=http%3A%2F%2Fi.imgur.com%2FByXgavO.png&hash=5758272223ddf08c79bb5e03c4e47e4f)
