Hello guys!
Due to work getting in the way of my previous project and seeing it now, I can say for sure that that case needs rework, and thus Project Reality is born!
The whole idea here is a quick and dirt design, sporting the parts that I already have with minimal budget spent!
I'm fairly confident of the way the case is right now, and wanted to post here for some inputs on what I can do to make it better, to make it smaller and more efficient!
So what are the constraints here?
Components!
- CPU - i5 4460
- MOBO - Gigabyte GA-H97M-D3H matx
- GPU - PNY GTX 970 (reference design)
- HDD - 3.5" 2TB, 2.5" 250GB SSD
- PSU - Cougar 550w ATX
Here is the thing... I was designing cases with 4-5L in mind, to which I would have to change basically every component, I was even thinking of doing custom watercooling loops... however reality has dawned me that sincerely for now I dont need a new pc, and just need that space back!
The design is for a vertical case... I know its not the most efficient layout, given that we need space for cables, and for the vents... However in my case the space that is at a premium is the horizontal one, not the vertical, aside that I have always been in love with such designs.
I thought a mix of industrial with minimalist would be good, and thus I have used everything to be as functional as possible in the case.
The side is even more so
and the back shows that the feet are the front of the case and the vent entry....
Well as is usual in such design I have placed 2x 120mm fans on the bottom to create a tunnel effect, however I'm still debating on how many fans I should place there, with a minimal change I can put 6x 80mm fans, however I'm still searching on how loud that would be.
Which leads me to the exit of the air....
Anyway here is the internal layout as it is now..
The storage would be attached to the back of the case, with a L bracket, I thought of putting a motherboard tray in there, however I have opted in the end to do without it and use a longer riser to accommodate the storage there.
The layout itself is very common. As can be seen...
And I have put the power button where it is due to it also helping support the weight of the psu, however, I'm currently tending to move it to the side of the case, it would still be used that way, however I would have a clear front panel.
The bend radius is taken into account, and I have thus steered clear to smash any components against the front panel corners, and acrylic can do a very tight bend radius.
In the end the part count is going to be very low for the case
Parts
- 3x Acrylic panels of 5mm and 1x of 8mm which is going to be the top of the case, the extra thickness is due to it supporting the weight of the PSU.
- 20x L brackets, and 20x screws, 12x for the panels to be together and the others are for the storage, which is going to receive dampening from rubber fittings
- 1x power button
Measurements!
This is a SFF forum! We have to know the size! 360mm (H), 190mm (D), 269mm (L) Vol = 18,3L
I'm really open to suggestions on what can be improved in this case!
Here is what I'm trying to do away with!
and here is the giant stuff occupying all that space!
Really appreciate any help!
Components!
- CPU - i5 4460
Parts
- 1x power button
Measurements!
