Hi all,
I'm trying to figure a way to mount a dust filter on my intakes. I'd rather not have to screw anything in as I'm trying to design a case with as few holes as possible.
I'm thinking of installing filter material permanently to the inside of the side panels by gluing the material on the perimeter of the grill, as well as along the areas between the grill pattern so that the filter material doesn't pull towards the fan like a sail.
For the moment, the case I'm designing is only a personal project, so I'm not worried about people being mad about not being able to remove the filter. My idea is that every once in a while I'll just unscrew/unclip the panel and blow compressed air from the inside to blow the dust off (or use a vacuum).
So... gluing a low-density foam to aluminum or steel... yea or nay? How would it hold up under the fan's constant tugging? The fan I'm planning on using pushes A LOT of air, too. Upwards of 150 CFM.
Should I just suck it up and compensate for the extra millimeter or two it'll take to use a framed filter? Maybe commit once and for all to steel and use a magnetic filter?
